Nik
PIO Event Handler
Trying get a handle on using event handling for PIOs.(Pun fully intended)
Mostly look to build my parameters programmatically rather than using the Plug In Manager.
Here's a little script I've added to a Point object. My understanding is that I should build my parameter widgets during the respond2Widget prep event, but that event never seems to get triggered.
When I select the object from my Tool Palette it triggers a respond2SurfaceEdit, then a resetEvent. When I click in the drawing to place it I get respond2SurfaceEdit, resetEvent, respond2SurfaceEdit, resetEvent.
Am I missing something? If so what am I missing? Where can I find some documentation on this?
code below:
def eventHandler():
    def resetEvent():
        pioName, hPIO, recHand, wallHand = 0, 0, 0, 0
        ok, pioName, hPIO, recHand, wallHand = vs.GetCustomObjectInfo()
        if ok:
            vs.Rect(0,0,1,1)
    def parametricPref():
        None
    def respond2SurfaceEdit():
        None
    def onSpecialEdit():
        None
    def onReshape():
        None
    def onButtonPress():
        None
    def respond2WidgetPrep():
        vs.vsoAddParamWidget(9, 'testing', 'A Test')
        vs.vsoSetEventResult(-8)
    def onParamValChange():
        None
    def triggerEvent(argument):
        eventSwitcher = {
            3 : resetEvent,
            4 : parametricPref,
            5 : respond2SurfaceEdit,
            7 : onSpecialEdit,
            9 : onReshape,
            35 : onButtonPress,
            41 : respond2WidgetPrep,
            44 : onParamValChange,
        # Get the function from switcher dictionary
        func = eventSwitcher.get(argument, lambda: "nothing")
        vs.AlrtDialog(func.__name__)
        # Execute the function
        return func()
    theEvent, theButton = vs.vsoGetEventInfo()
    triggerEvent(theEvent)
vs.PushAttrs
eventHandler()
vs.PopAttrs
okay! I learned somethings...
respond2SurfaceEdit should actually be called OnInit
the vsoAddParamWidget command should be in OnInit
and to actually be able to add widgets and adjust their visibility/enabled state  you need to include the following at the beginning of the OnInit:
        ok = vs.SetObjPropVS(8, True) #kObjXPropHasUIOverride}
        ok = vs.SetObjPropVS(12, True) #kObjXHasCustomWidgetVisibilities}
