PeterYip 14 Posted March 29, 2020 Every now and then I copy a bunch of things from other 2d drawings, some in group, and some in symbols etc. When I am turning these draw into a 3D model, often when I decompose them a lot of them will became screen plane, I was wondering is there a quick way to turn everything into layer plane ? plugins or Marionette ? Many thanks Quote Share this post Link to post
markdd 695 Posted March 29, 2020 The quickest way I know is to use the Custom Modification command from the Tools Menu and set the selection criteria to Plane > Screen. Then change everything to Layer in the Object Properties box that appears. You can make sure that it looks inside groups as well..... You can also set the tool to create a script which will semi-automate the process after that. 1 Quote Share this post Link to post
Phil hunt 75 Posted March 29, 2020 there was a nice free plug in that turns all screen objects to layer plane it was on a site called vectorcad or something like that......someone will know on the forum Quote Share this post Link to post
Phil hunt 75 Posted March 29, 2020 https://forum.vectorworks.net/index.php?/topic/54674-screen-plane-only/&do=findComment&comment=281672 try this Quote Share this post Link to post
Phil hunt 75 Posted March 29, 2020 (edited) i think this may be it.....The instruction are in under documentation in the file. PlaneMode (1).zip Edited March 29, 2020 by Phil hunt 1 Quote Share this post Link to post
PeterYip 14 Posted March 30, 2020 13 hours ago, markdd said: The quickest way I know is to use the Custom Modification command from the Tools Menu and set the selection criteria to Plane > Screen. Then change everything to Layer in the Object Properties box that appears. You can make sure that it looks inside groups as well..... You can also set the tool to create a script which will semi-automate the process after that. Thanks, thats perfect. Quote Share this post Link to post
PeterYip 14 Posted March 30, 2020 13 hours ago, Phil hunt said: i think this may be it.....The instruction are in under documentation in the file. PlaneMode (1).zip 31.15 kB · 1 download Thanks a lot, will give it a go. hopefully it will works on 2020 as well. Quote Share this post Link to post
Jim Smith 333 Posted May 5, 2020 (edited) I downloaded the script was not able to get it to run on VW2019. The workspace editor doesn't see it Edited May 5, 2020 by Jim Smith Quote Share this post Link to post
PeterYip 14 Posted May 5, 2020 @Jim Smith Yes it does work. Haven't test it much but from what I have tried it works perfectly. If you follow the instruction, and just place the 2 vsm file in the plug-ins folder it should comes up in workspace editor. Quote Share this post Link to post
Jim Smith 333 Posted May 6, 2020 @PeterYip @Phil hunt I see what the issue was. In the documentation the suggestion is to look for the Menu header with the name of: ´panta rhei' Finding the Plug-in "Object to Screen Plane" or "Objects to Layer Plane" does the trick & it works like a charm, THANKS! Quote Share this post Link to post
