Sam Jones
Resource Folder inside Resource Folder
Using VS can I create a resource folder inside another resource folder.  Can I move a folder into another folder.  SetParent() does not seem to work.
I would think SetParent() should work. You can also try InsertSymbolInFolder()
How are you getting the Handle to your created resource folder? Are you sure the Handle you are passing to SetParent() is correct.
The script below fails when the parent exists and when the parent cable does not exist.  It also fails using InsertSymbolInFolder().  Putting a BeginFolder inside a BeginFolder also fails.
PROCEDURE PutFolderInFolder;
VAR
    FolderName : STRING;
    FolderHdl : HANDLE;
    Folder2Hdl : HANDLE;
    ok : BOOLEAN;
BEGIN
    FolderHdl := GetObject('AP Cable Folder');
    IF FolderHdl = NIL THEN
        BEGIN
            NameObject('AP Cable Folder');
            BeginFolder;
            EndFolder;
            FolderHdl := LNewObj;
        END;
    NameObject('Inside AP Cable Folder');
    BeginFolder;
    EndFolder;
    Folder2Hdl := GetObject('Inside AP Cable Folder');
    ok := SetParent(Folder2Hdl, FolderHdl);
    IF (NOT ok) THEN
        AlrtDialog('ok set parent is false');
    {InsertSymbolInFolder(FolderHdl, Folder2Hdl);}
END;
RUN(PutFolderInFolder);
SetParent() does work for placing resources in folders, but as you observe it fails for symbols. I suspect this is due to somewhat simplistic error checking; you can't place a record in a symbol folder, only a record folder, etc. I'm guessing you are restricted from placing a folder in a folder via script.
I would file this as a bug, and if it's WAD have it moved to an enhancement request.
I would expect nested BeginFolders to fail. The first folder would not yet exist when the nested one was trying to be created.
LNewObj only works (as far as I know) on SOME objects that are actually visible in the drawing. I would not expect it to work on resources.
Check out CreateFolderN in the function reference.
Quote
VAR
    FolderHdl : HANDLE;
    ok : BOOLEAN;
BEGIN
        BEGIN
            BeginFolderN(16);
                BeginFolderN(16);
                EndFolder;
            EndFolder;
        End;
        AlrtDialog(Concat(FolderHdl,'  ',Folder2Hdl));
    IF (NOT ok) THEN
END;
CreateFolderN creates symbol folders in the operating system not in the Resource Manager.
Did you run the modification to the sample code I posted? I got folders in the Resource manager.
It was in the quote in my post above. I had my window set to narrow and could not see the Code block icon and assumed that they had updated the forum and removed it.  Reposted here. This is a minor modification to your code that puts nested folders in for me.
The 16 in the BeginFolderN specifies Symbol folders, but I think you can use most of the type codes for Definitions in the VS Appendix Object Type table that are listed as Definition.
VAR
    FolderHdl : HANDLE;
    ok : BOOLEAN;
BEGIN
        BEGIN
            BeginFolderN(16);
                BeginFolderN(16);
                EndFolder;
            EndFolder;
        End;
    IF (NOT ok) THEN
END;
Success !!  I did not understand the explanation of the BeginFolderN() command.  I do now.
Thanks.
