Using the plant tools and reference data
Plant tag line weights:
I used the following in Vectorworks 10 works to change the line weight of the plant tag, but I cannot find that command in 11. Where is it?
'You can customize this setting (full disclosure requires that I reveal this can be done in VW10 OR VW11). Open the Plug-in Editor (also known as the Create Plug-in.. command) and scroll to the Plant.VSO object. Highlight it and click the "Strings" button. Open string #4001. This string contains the lineweight of the plant tag in mils. Change this and it will change for all plants.'
PLANT REFERENCE DATA BASE
I can't get the data base I updated from 10 to be the default base in 11. How do I do this?
PLANT LIST
I figured out how to customize the plant list after speaking to John Altorio who does some beta testing. It would be a good idea to have the steps spelled out. If they are, they should be referenced to in the manual.
