Everything is invisible
JulieK
When I open my drawing, everything is invisible.  If I drag a rectangle across the screen, the object info palette says that there are objects selected, but I can't see them.  All of my classes and layers are turned on, and the classes and layers are set to "show/snap/modify others".   Only this particular file seems to be affected;  other files are displaying normally.  In Vectorworks preferences I tried setting the background to black, but nothing happened.
2 answers to this question
Check and see if you have the Clip Cube turned on but selecting an area of the drawing that has no objects.
Check if you have Unified View turned on and a Design Layer selected that has a different Layer Scale than the other layers. With Unified View on, only layers with the same scale as the active layer are visible.
