Data tagging objects with marionette
  • 1 month later...
Hello Martin,
There are no default nodes, but there are a few scripting calls that have been added to Vectorscript and Python in 2019. You can find them here. https://developer.vectorworks.net/index.php/VS:Function_Reference#Data_Tag_Interface_Library
In order to place a data tag, you could use the Symbol node and then I imagine you could create a custom node that uses the first command, https://developer.vectorworks.net/index.php/VS:DT_AssociateWithObj, to associate it with a Space. I think this would work if you are placing these Data Tags in design layers, but if you are trying to place them in the Annotation Space of a viewport, I would recommend adding Data Tags manually. There is a way to tag all relevant objects at once, so I imagine a script wouldn't bring much added efficiency.
You can do this by choosing "Select Eligible Objects Mode" in the Mode bar of the Data Tag tool. If your tag is set to read a field from the Space object, you can hover over a Space with that Data Tag style selected and all spaces will highlight red. This works with any object type that the Data Tag is looking for. I took a screenshot of it using Doors and a Door-specific tag.
This sounds very promising, thank you @sbarrett! Unfortunately I do not have any scripting background and I would need some kind of tutorial on how to translate VS:DT_AssociateWithObj into a node. The syntax changes a bit I guess?
Thanks for helping so far!
Hi @Martin Lerch, I tested it and it appears to work great. The issue that you will have is that any geometry created by a Marionette script will be grouped. after the script is run and you ungroup the data tags, they appear to be associated properly with the space.
I would recommend having the data tag also be the output of the script, that way you can manipulate it further along in the script (after it has been associated) if you wish.
Thanks for your feedback Sarah!
Yes, I saw that. In my marionette project I place every Data Tag on a different Sheet Layer first and associate it after with the object. It works great so far (and without the grouping problem).
1091433381_Bildschirmfoto2020-05-04um15_31_20.thumb.png.cb371cb0e914ccef2a5193e5ffca5ac7.png
That's what I've tried before but without success... how do I have to add this in the node?
Thanks a lot,
Martin
I have edited the node so that the "result" shows up and the associated data tag is now an output as well. This network will work when running it on a single design layer, but because of how Marionette works (creating groups of objects), placing them on multiple layers at the same time is rather tricky and I don't recommend it. Also, I don't recommend trying to use this with viewports. If you are tagging objects in viewports, I think using the data tag as-is works better than trying to script it.
DT_AssociateWithObj.vwx
