DIN RAIL TERMINAL
Hello all,
Does anyone know how to expand the number of blocks on a din rail terminal?
I have to draw a 150 port din rail, and the only way I have found is to draw 3 48 block units then go into each separate block and change the name.
TB.02.1-48 creates fine, but I can't create anything bigger.  I can create TB.02.1-48 again under that, but then have to go into each block and re-label it. conductor
Also, anyone have a suggestion on documenting a 3 conductor wire into a DIN terminal?  I would like to show all three wires on the block.  As well, any good ideas on how to make an internal jumper on the output side of a block?  ie. jump TB.02.27 to TB.02.29 on the output side?
Thanks for any assistance
Chippy
