Sanchia Posted March 20, 2020 Share Posted March 20, 2020 Hello there, I am trying to import a DWG file. The document is 1:500 @ A1. I open a new doc and set up the page to A1 and change the scale to 1:500 I check 'use detected DXF/DWG file units' then check 'For unitless DXF/DWG file use Millimeters' And check 'Change current Vectorworks doc units to match the specific DXF/DWG file units.' The dwg doc imports and fits the A1 sheet however it is scaled at 1:1 I then use the 'Scale Objects' 'Symmetric by distance'. On the doc at this point 5m =10 and i change it to 10 = 5000. If i click okay - the document is scaled correctly however there is no text. If i click on 'Scale Text' everything disappears - no text no drawing. Thanks for your time. Quote Link to comment
0 Vectorworks, Inc Employee Nina Ivanova Posted March 20, 2020 Vectorworks, Inc Employee Share Posted March 20, 2020 3 hours ago, Sanchia said: The dwg doc imports and fits the A1 sheet however it is scaled at 1:1 Try "This scale" from the Advanced DWG/DXF Import options and set the scale to 1:500. DWG import always creates a new design layer with a calculated scale ("Fit to Page", default choice) or the specified scale ("This Scale" option). 1 Quote Link to comment
Sanchia
Hello there,
1 answer to this question
