axhake
VW 2020 - SP3 Problems - Export to DWG
Posted (edited)
I have just updated VW2020 to SP3 and exported some file to DWG that I have been exporting earlier in the day, after export the DWG.
On opening the file in ProjeCAD (also checked in AutoCAD) the DWG is a mess with lines all over the place.
Extract of model below - Original exported prior to SP3:
After updating to Sp3:
I have duplicated this in a test file by creating a extruded rectangle (5x5x5m) square to grid.
Exported to DWG using the same settings as previously used and opened in ProjeCAD
Each face is now subdivided.
In the same file I then created two additional extruded rectangles, one square to the grid and one rotated.
Plan view:
3D perspective View:
Again exported to DWG using the same settings as previously used and opened in ProjeCAD
3d Perspective view:
The top and bottom surfaces of the extruded rectangles that was rotated are now a mess.
The extruded rectangles that are square to the grid appear intact apart from each face now subdivided.
Can you please advise how to revert back to VW SP2 as I have wasted a few hours now messing around with this.
And fix this ASAP
Setting as used in the export for reference:
(Have also tried changing the settings but same results.)
Edited by axhake
3 answers to this question
Posted (edited)
Did I miss an announcement of SP3 ?
Can you post a small demo DWG and/or VWX ?
Edited by zoomer
I can do in the morning as have finished for tge evening.
ps.
Regarding reverting back to previous version, i remembered how to do it, was getting frustrated trying to get work out.
Alan
Posted (edited)
OK so you can work again.
I haven't seen any hint of SP3 on all sources,
maybe reverted after your thread.
As for the Subdivisions,
I have seen that in previous VW Versions.
Maybe no more since 2019.
In Bricscad I can DMSIMPLIFY all DWG Solids at a time.
But somehow your first screenshots look a bit like Geometry
was a) far from internal origin or b) came in/out at wrong scale.
Edited by zoomer
