How to uninstall content package?
Travis.Designer
5 answers to this question
17 hours ago, Rob Books said:
if you are in 2018 or newer, you no longer need to download all the content.  it is available through the Resource Manager.
to remove any libraries, go into the application folder and  find the libraries folder.  delete anythign you do not need there.
Hi Rob Books
I think content package is not included in default. for example Object - Building Furniture, After download content pack, I have to click Refresh Library. They will show more file .vwx
I go to location: C:\Program Files\Vectorworks 2020\Libraries\Objects - Building Furnishings
There're file .proxy. Is It ok if I delete these files?
1 hour ago, Rob Books said:
There are two icons that you should have active, the Vectorworks symbol that is the general libraries that everyone gets, and if you are on Service Select Program, you will have the Cloud icon.  two separate libraries.  make sure that they are highlighted at the top of your Resource Manager like the image attached.  if not reach out to your distributor they can help you.
Hi Rob
I did as you said. There' no change.
