Travis.Designer Posted March 17, 2020 Share Posted March 17, 2020 Hi I installed a lot of content package. Now I run out of storage space. How can I uninstall these packages? Quote Link to comment
0 Travis.Designer Posted March 19, 2020 Author Share Posted March 19, 2020 17 hours ago, Rob Books said: if you are in 2018 or newer, you no longer need to download all the content. it is available through the Resource Manager. to remove any libraries, go into the application folder and find the libraries folder. delete anythign you do not need there. Hi Rob Books I think content package is not included in default. for example Object - Building Furniture, After download content pack, I have to click Refresh Library. They will show more file .vwx I go to location: C:\Program Files\Vectorworks 2020\Libraries\Objects - Building Furnishings There're file .proxy. Is It ok if I delete these files? Quote Link to comment
0 Travis.Designer Posted March 20, 2020 Author Share Posted March 20, 2020 Hi Rob Books There's not online content in Resources Manager. There's no cloud icon. I checked Tools > Options > Vectorworks Preferences > Session Tab > checked "Enable Online Content". How can I fix it? I use Vectorworks 2020 Quote Link to comment
0 Josh Schulman Posted March 20, 2020 Share Posted March 20, 2020 Hi Rob, I spy in your Resource Manager Lumenpulse. Does that mean it is being added to the libraries? 😁 Quote Link to comment
0 Travis.Designer Posted March 20, 2020 Author Share Posted March 20, 2020 1 hour ago, Rob Books said: There are two icons that you should have active, the Vectorworks symbol that is the general libraries that everyone gets, and if you are on Service Select Program, you will have the Cloud icon. two separate libraries. make sure that they are highlighted at the top of your Resource Manager like the image attached. if not reach out to your distributor they can help you. Hi Rob I did as you said. There' no change. Quote Link to comment
0 Travis.Designer Posted March 20, 2020 Author Share Posted March 20, 2020 4 hours ago, Rob Books said: Try going into the gear menu in the RM and click refresh libraries. I just had to do this myself. Hi Rob Yes, I did. It' only show download content. Quote Link to comment
Travis.Designer
Hi
5 answers to this question
