How to uninstall content package?
Travis.Designer
11 answers to this question
if you are in 2018 or newer, you no longer need to download all the content.  it is available through the Resource Manager.
to remove any libraries, go into the application folder and  find the libraries folder.  delete anythign you do not need there.
Hi Rob Books
I think content package is not included in default. for example Object - Building Furniture, After download content pack, I have to click Refresh Library. They will show more file .vwx
I go to location: C:\Program Files\Vectorworks 2020\Libraries\Objects - Building Furnishings
There're file .proxy. Is It ok if I delete these files?
the proxy files are what makes everything visible in the Resource manager, they hold the thumbnails that are shown.
unless you are an institution, you no longer need to download the Package files for symbols, they are all available in the Resource Manager to download as needed.  The other place to check for the files is in your user folder, also in the Libraries folder.  if you click on Tools>Options> Vectorworks Preferences,  you can find your user folder.
There are two icons that you should have active, the Vectorworks symbol that is the general libraries that everyone gets, and if you are on Service Select Program, you will have the Cloud icon.  two separate libraries.  make sure that they are highlighted at the top of your Resource Manager like the image attached.  if not reach out to your distributor they can help you.
Hi Rob
I did as you said. There' no change.
