Missypa
DOOR STYLE
My door won't change to the style I ask when I convert it. It was fine on my first door but now doing the other doors it doesn't change but on the top right hand corner the name of style I have chosen is there but not understanding why its still the same. It stays the same with the original, I've put it on open GL but still the same. Such a simple thing but not understanding why it wont go to a different door style. All classes are the same if that helps.
Thanks in advance!
2 answers to this question
Edit the door style and check to see what parameters are "by style" and what parameters are "by instance".  Parameters that are by instance won't change when you assign a style.
If you get stuck, post a file here with the door that isn't doing what you want.
