AngeliqueRoggeveen Posted March 12, 2020 Share Posted March 12, 2020 Hi. So my question is the following. I have to make a wall that has a curve at the top. Like the roof is bend in a round shape. So what i did is: i have made a wall for the straight bottom part which is 3m high. And for the top part that has a curve ive made an extrusion. I woud like to merge these together but i dont know how. Please help. xx- Angelique Quote Link to comment
0 zoomer Posted March 12, 2020 Share Posted March 12, 2020 I think the better way is just to create a Wall, build an object like a roof above and use AEC : "Fit Walls to Object" http://app-help.vectorworks.net/2020/eng/index.htm#t=VW2020_Guide%2FWalls%2FFitting_walls_to_defined_geometry.htm&rhsearch=fit walls&rhhlterm=fit walls&rhsyns= It even works for Curtain Walls .... 1 Quote Link to comment
0 CipesDesign Posted March 12, 2020 Share Posted March 12, 2020 Try using the Fit Walls To Object command. 1) create the rounded geometry as a 3d object, making sure that the object completely covers/overlaps the Walls. Put this new object on a new Design Layer (different form the Walls). 2) Select the Wall(s) to be reshaped, then choose the Fit Walls to Objects command; select the new Design Layer as the "Fit To" Layer. This should result in the Walls following the contour of the rounded object, although as a note, the curves on the Walls will actually be a series of segmented flats (not a true curve). 1 Quote Link to comment
0 Pat Stanford Posted March 12, 2020 Share Posted March 12, 2020 Zoomer and CipesDesign are correct. There is no way to "Merge" your two objects and keep the resulting object as a Wall. You could Add Solids if you don't mind it being a Solid Addition instead of a Wall, but you lose the ability to do things like insert Doors and Windows and you will lose the hybrid ability to see the Wall Components in Top/Plan view. Quote Link to comment
AngeliqueRoggeveen
Hi.
Please help.
xx- Angelique
3 answers to this question
