How to reduce speed in Game mode?
There may be two answers.
First:  Q makes it go faster.  E makes it go slower.
Second.  There is a bug in VW on Mac (not sure if it also applies to windows) that makes the Walkaround tool in gamer mode go crazy and spin out of control if a second monitor is attached.  If E doesn't solve your problem, try running with just one monitor or mirror the monitors.
Hi Michaelk
I answer as below:
1. I use Wacom Pen, when I put nib on tablet, it is similar left click. Then I drag very short distance. They react out of control.
2. I use window 10. and I only use laptop screen.
Do you have any idea?
Best regards
Travis
On 3/13/2020 at 1:09 AM, michaelk said:
I use an XP-Pen tablet on a Mac.  It works for me.  Try hitting the E key several times to slow it down.
If that doesn't help, does it work ok with a mouse?
Hi Michaelk,
I set lowest value - Speed increment factor.
Beside that. I also try using mouse mode. It work but It not make scene because the feeling is not similar with pen mode.
Edited by Travis.Designer
