A worksheet created in 2016 seemed to become partly dysfunctional when opened in 2020. A function with the same basic structure, but returning different values from the fields of a record format, was used to display text in several columns of one database header.
Column A ='Outline Schedule of Works'.'Work Sub-Category'
Column B ='Outline Schedule of Works'.'Location'
etc
It worked fine in all but one column of the database header. Despite the structure being identical to the other columns. When a neighbouring function was pasted into the failing column it too became dysfunctional, returning only itself in the sub-rows. Simple fix:- delete the column. Add a new one in the same place. Formula then worked correctly.
thinkingpencil
etc
0 answers to this question
