The smoothing angle should be preventing both of these lines from rendering. They represent the end of the fillet arc between the flange and web on a W shape beam. The beam has pieces cut from and added to it. If changed from dashed hidden line rendering to hidden line rendering the dashed line will be removed. So this is two different functions that are not operating as expected. Both should should be reacting to the smoothing angle setting.
LarryO
The smoothing angle should be preventing both of these lines from rendering. They represent the end of the fillet arc between the flange and web on a W shape beam. The beam has pieces cut from and added to it. If changed from dashed hidden line rendering to hidden line rendering the dashed line will be removed. So this is two different functions that are not operating as expected. Both should should be r eacting to the smoothing angle setting.
2 answers to this question
