Why are these lines rendering?
LarryO
The smoothing angle should be preventing both of these lines from rendering. They represent the end of the fillet arc between the flange and web on a W shape beam. The beam has pieces cut from and added to it. If changed from dashed hidden line rendering to hidden line rendering the dashed line will be removed. So this is two different functions that are not operating as expected. Both should should be r eacting to the smoothing angle setting.
2 answers to this question
There are a couple of other basic functionality issues with rendering that keep me from doing more 3d work in VW. Like OpenGL not rendering section viewports with shadows and grey tones. Not being able to figure out how to define a hatch to appear where an object is in section like cutting through a steel beam results in solid black, again a section viewport.
