Takeshi_Kimura
Type of Pop-up Field of a Record format
Hi Takeshi,
I asume you checked a parametric record, in this case the number would be "3".
Did you see the different tables in the doc.
Data Record:
 -"4" Text (Didn't check it, but the pop up must be text in that case, )
 -"8" Number-fractional
Param Record:
- "3" Number (Equivalant to 8 off Data Record)
- "8" Pop-Up
regards,
Patrick
I believe you want to follow the parametric constants now, and that there is an object variable that will get you the numeric type.
I am trying to create a pop-up field in a document record format (Not a parametric format). When I use GetFldType() on a pop-up field in a document record format that I've created through the interface, it returns '8' however when I use NewField('Record Name','FieldName','None',8,0) the script creates a fractional number field. Is it not possible to create a pop-up field via script? And if so, how do you set the list of possible options?
Thanks!
Marcus Wuebker
