cberg
Elevation Viewport of Generic Solids on Different Layers
Is there any setting that would eliminate the line between two generic solid type objects that are put on different layers in a section viewport that shows the objects in elevation?
838133802_ScreenShot2020-03-04at7_52_21PM.thumb.png.044bf64021399d52e3f47618206275e0.png1094220871_ScreenShot2020-03-04at7_54_50PM.thumb.png.c910a72011fafe99dae1a644f191898a.png
TEST.vwx
Posted (edited)
This may be a bug or it may be a "feature".  I discovered that you had to select Merge with Structural Objects in Sections.  However, the line only goes away when the object is an extrude.  If you turn it into a generic solid, the line shows up.
What exactly is the difference between an extrude and a generic solid (besides the face that one has history and the other does not).  There does not appear to be a logical reason why one would behave one way and the other another.
Help me out here.... Bug or Feature???
1615580156_ScreenShot2020-03-05at4_56_35PM.thumb.png.55417f4cd2d89e68397855d82fc1300a.png628348874_ScreenShot2020-03-05at4_57_18PM.thumb.png.85406f95a9878c565440cd7e428a0729.png
35531240_ScreenShot2020-03-05at4_59_35PM.thumb.png.eca3cd8c4bd18633c97149ce84b31e45.png
TEST2.vwx
Edited by cberg
There shouldn't be any difference in this case between an extrude object or a generic solid, assuming they have "Merge with Structural Objects [...]" checkbox checked. I experimented a bit and was getting split lines in some cases but not others, though the fill was merged. (You can test that the fill has been merged by converting the viewport to a group, and checking if the fills inside the group that you expect to be combined are combined into a single polygon or polyline.)
The merging can't simply use our standard Add Surface code because the incoming objects might have different pens from each other, no pen on certain edges, or even different pens on different edges (such as the individual component polygons from a wall with components.) That's why if you do that conversion of the viewport to a group, you'll find the edges are separate objects from the fills, and they are always drawn on top of the fills. It looks like in certain cases edges that should have been removed because they would be covered by the fills are not, and then they're being drawn on top.
This should be reported as a bug if it hasn't already.
Thank you for responding and providing insight into how the software should work. I did try to submit this as a bug.  But I haven't had any confirmation regarding a tracking number.
Any progress on when this will get resolved.
