cberg Posted March 5, 2020 Share Posted March 5, 2020 Is there any setting that would eliminate the line between two generic solid type objects that are put on different layers in a section viewport that shows the objects in elevation? TEST.vwx Quote Link to comment
cberg Posted March 5, 2020 Author Share Posted March 5, 2020 (edited) This may be a bug or it may be a "feature". I discovered that you had to select Merge with Structural Objects in Sections. However, the line only goes away when the object is an extrude. If you turn it into a generic solid, the line shows up. What exactly is the difference between an extrude and a generic solid (besides the face that one has history and the other does not). There does not appear to be a logical reason why one would behave one way and the other another. Help me out here.... Bug or Feature??? TEST2.vwx Edited March 5, 2020 by cberg Quote Link to comment
Vectorworks, Inc Employee Andrew Bell Posted March 9, 2020 Vectorworks, Inc Employee Share Posted March 9, 2020 There shouldn't be any difference in this case between an extrude object or a generic solid, assuming they have "Merge with Structural Objects [...]" checkbox checked. I experimented a bit and was getting split lines in some cases but not others, though the fill was merged. (You can test that the fill has been merged by converting the viewport to a group, and checking if the fills inside the group that you expect to be combined are combined into a single polygon or polyline.) The merging can't simply use our standard Add Surface code because the incoming objects might have different pens from each other, no pen on certain edges, or even different pens on different edges (such as the individual component polygons from a wall with components.) That's why if you do that conversion of the viewport to a group, you'll find the edges are separate objects from the fills, and they are always drawn on top of the fills. It looks like in certain cases edges that should have been removed because they would be covered by the fills are not, and then they're being drawn on top. This should be reported as a bug if it hasn't already. 1 Quote Link to comment
cberg Posted March 10, 2020 Author Share Posted March 10, 2020 Thank you for responding and providing insight into how the software should work. I did try to submit this as a bug. But I haven't had any confirmation regarding a tracking number. Quote Link to comment
cberg Posted June 29, 2020 Author Share Posted June 29, 2020 Any progress on when this will get resolved. Quote Link to comment
