DaleW
Window cap break line thickness
Hi,
Does anyone know how to set a thickness for the break/cap line for a window or door?
I would like the make it match the wall as below.
Thanks
Hello @DaleW,
I have tried this with Window in Wall and was able to modify this from the Window's OIP -> Jamb and Sash group -> Jamb Depth parameter. I suppose that there should be similar parameters for other objects in walls.
Best Regards,
Nikolay Zhelyazkov
Hi Nikolay,
I was able to achieve this by going into the wall style, then -> edit wall attributes -> and selecting 'use component line attributes'. Then in the window OIP, at the top it has a drop down menu for 'Break', I selected 'full break with caps' and it achieved the result I was after.
As always, thanks for your help.
