Gaetan Posted October 13, 2005 Share Posted October 13, 2005 Hi ! Amother basic question that I can't find the answer in the documentation or the Tech Board... sorry. When I'm drawing a polygon, how can I enter the angle for each segment relative to the last segment drawn. Because, the angle is always relative to the X axe (horizontal). I'm sure there is a solution, because this a function everybody need for plans, but I can't find it. I'm waiting for your help. Thank you Gaetan, VW 11.5, Mac OS X Quote Link to comment
Guest Posted October 13, 2005 Share Posted October 13, 2005 Gaetan - I don't quite follow. Can you provide a better explaination, perhaps with real numbers? Quote Link to comment
Kaare Baekgaard Posted October 14, 2005 Share Posted October 14, 2005 I use keyboard input. Do you know, that you can use the numeric input field as a calculator? In the angle field (is that the right term?) just write 30+25 for instance. Where 30 would be the angle of your previous segment and 25 the relative angle of the new segment . VW will calculate the result for you and restrain the new segment to the correct angle. Quote Link to comment
Gaetan Posted October 14, 2005 Author Share Posted October 14, 2005 Kaare, thank you, this tip could help me very much. Katie, sorry, I don't speak english very well, so sometimes it is confious... thank you. Gaetan Quote Link to comment
