BGD Posted March 1, 2020 Share Posted March 1, 2020 Hi, How can I create highquality viewport of 3D view of a plant? In the attached example, as you can see, when you zoom in the 3D view of plant is looking very blurry. I want to create viewport that looks very similar to when you see 3D view of the plant in design layer. ThanksTest 3d view.vwx Quote Link to comment
Pat Stanford Posted March 1, 2020 Share Posted March 1, 2020 The default resolution of Sheet Layers (and therefore Viewports) is 72 dpi. Go to the Organization Dialog:Sheet Layer pane and you will see the dpi setting of each sheet. Edit that and increase to 200 or more DPI and you should get what you want. Be careful to not go crazy. Your resolution on screen is probably less than 150 dpi, so for working you don't need 600 or 1200 and it will just slow you down. You can always change the resolution and re-render when you really need the hi-res output. 1 Quote Link to comment
