Progress Dialog
twk
SDK Only as far as I know.
I used to use the Message command for this, but a few versions ago it stopped displaying until the script run completed. I think it was going to be fixed, but I have not tried in VW 2020.
The AlertInform dialog box would be good for this as the Minor Alert boolean makes it show at the bottom edge of the drawing window where the rendering progress indicator sits, but only for the first run. After the first run it automatically is (or at least was in VW2017) it automatically defaulted to a full dialog box.
I hope one of these might work for you.
Ahh thats a shame, I shall explore some external python libraries.. WxPython, TKinter etc.
This still happens sadly..
Edited by twk
Hello
I am not sure, if have understood correctly your question. However I can say the following:
  • the progress dialog can be displayed without the vs.ProgressDlgStart() and terminated without the vs.ProgressDlgEnd() call.
  • without calling vs.ProgressDlgClose() the dialog window stays open until the script terminates.
  • vs.ProgressYield() has to have a numeric parameter vs.ProgressYield(1), otherwise pyhton errors are thrown.
  • vs.ProgressYield(int) has to be called otherwise the other messages like vs.ProgressDlgSetMeter(message) are not refreshed on the dialog window.
def messagePtest3():
	selCount = 10
	def DoTheWork():
	#	vs.ProgressDlgStart(100,selCount)
		for i in range(selCount+1):
			vs.ProgressDlgYield(1)
			vs.ProgressDlgSetMeter(str(i))
			vs.Wait( 1 )	#well, we work by waiting
	vs.ProgressDlgOpen( "I'm about to do some work", False )
	vs.ProgressDlgSetMeter("") # this resets previous values, if vs.ProgressDlgStart is not callded
	DoTheWork()
	# vs.ProgressDlgEnd()
    # vs.ProgressDlgClose() # if close is not called, the dialog stays open until the script terminates
best regards,
relume
Edited by relume
  • 2 years later...
Hi
Also Failing here. Seems the python script is waiting for the python execution and not for Vectorworks. If I as example importing 10 Symbols from a source it takes about 10 seconds. The progress bar (and Message Window) ends in 1 Second. If i build in 10 seconds of wait or sleep function it is visible 10 seconds but the execution takes then 20 seconds.
Next try would be to run the function inside a dialog loop
def place_symbols():
	vs.ClrMessage()
	vs.ProgressDlgOpen("Ersetze Objekte", False)
	if globals.settings['Ebene'] == 1: #new Layer
		vs.HideLayer()
		l_handle = vs.CreateLayer(globals.settings['Ebene Name'], 1)
		vs.HideLayer()
	vs.ProgressDlgStart(100, len(globals.pairs))
	counter = 1
	for target, source in globals.pairs:
		#vs.ProgressDlgStart(counter, counter)
		sym_name, [ListID, index] = source
		vs.ProgressDlgSetMeter('Ersetze' + sym_name)
		vs.Message('Ersetze' + sym_name)
		#time.sleep(1)
		if vs.GetObject(sym_name):
			vs.DelObject(vs.GetObject(sym_name))
		vs.ImportResourceToCurrentFile(ListID, index)
		vs.Layer(vs.GetLName(l_handle))
		vs.Symbol(sym_name, (0,0), 0)
		h_new = vs.LNewObj()
		counter += 1
		off_x, off_y, off_z = target['PositionXYZ']
		rot_x, rot_y, rot_z = target['RotationXYZ']
		vs.SetEntityMatrix(h_new, (off_x, off_y, off_z), rot_x, rot_y, rot_z )
	if 	globals.settings['Ebene'] == 0: #replace on active layer
			handle = target['handle']
			if handle != vs.Handle(0):
				vs.DelObject(handle)
	vs.ClrMessage()
	vs.ProgressDlgEnd()
