Bruce Glaser
Export from VW11 to VW10
Sorry if this is an old topic, I can't find a reference to it. We are having to export 11 files down to 10 and have noticed a major increase in file size which is causing problems. For example, a file in 11 which is 6.1megs has increased to 22.1 in 10. Is there a way around this problem?
Bruce,
It sounds like there are images in the file. Version 10 does not allow image compression, so any images will not take on the compression advantage as you see with embedded images in VW files for version 11.
Thanks Katie. There was 1 imported pdf document on one layer. When I deleted it, it brought the exported VW10 file down to the same size as the VW11 file. Hard to believe that one pdf image could have almost quadrupled the file size while exporting.
