BGD Posted February 24, 2020 Share Posted February 24, 2020 Hi, I cant understand why my walls are not casting shadow, whereas tree and fence does? Also, dont understand why all the shadows go awya when I make the pdf plan layer invisible (in navigation palette)? Thanks for the help. WIP 1.vwx Quote Link to comment
Guest Alex Sagatov Posted February 27, 2020 Share Posted February 27, 2020 @BGD This is a combination of a few different settings. First - The shadows are only appearing under your geometry / to the side at first due to the setting in OpenGL options for "On Ground Only". Uncheck this for more expected results. Second - Shadows require 3D objects in order to work as expected. Currently, under the wall area, there is only 2D geometry and two 3D shapes that do not have solid fills. Select the 3D objects (in this case, the ceiling grids) and apply a solid fill to them. Quote Link to comment
BGD Posted February 27, 2020 Author Share Posted February 27, 2020 Excellent. Thanks Quote Link to comment
