James Absmeier Posted February 23, 2020 Share Posted February 23, 2020 I scaled an entire portion of a floor plan smaller by mistake, how can I back the file up by at least 24 hours?? Quote Link to comment
0 Pat Stanford Posted February 23, 2020 Share Posted February 23, 2020 If this is more that the number of Undo steps you have then you will need to look at external backups. If you have enough recent backups set in Vectorworks Preferences:Autosave, you might be able to use one of them. If not, then it will depend on your external backup system. If you are on Mac and running Time Machine you might be able to get it there. Dropbox might be able to have an older copy. Otherwise you are out of luck. Good Luck. Quote Link to comment
James Absmeier
1 answer to this question
