Problem database object connection
Hi,
I used to work with database connection in vectorworks 2018, and was working almost properly....Now in vectorworks 2020 I connected the same Microsoft Access DB via ODBC. I can see the table into the record as usual. The problem is when I Try to connect object to a particular Row of this DB (Object Database Connection) the data is not apply.Nothing change even if I do the update vectorwork document. So this process was working in 2018 but not in 2020.
someone had this problem before, please let me know if it's a known bug...Don't want to waste much more time on this.
  • 2 months later...
  • 1 month later...
Hi,
I had this problem before but now it is working correctly...with the same file and the same database....I'm working on the V20 SP3.1.
The problem is I can't help you because I Didn't do anything to solve it...vectorworks mystery...
Hope you will get the same result.
