zsaunders Posted February 20, 2020 Share Posted February 20, 2020 I'm trying to taper extrude a tree trunk shaped 2D Polyline object I created. But I get the error: "Tapered Extrude creation failed due to invalid parameter(s) for at least one profile object." Any ideas why this fails? Quote Link to comment
EAlexander Posted February 20, 2020 Share Posted February 20, 2020 Not sure, but I assume the tightness of some of your grooves would make for self intersecting geometry and VW doesn't like that. You could duplicate the geometry, scale it down slightly, raise it up, convert both to nurbs and then Loft them together. That might work better. 1 Quote Link to comment
Kevin McAllister Posted February 20, 2020 Share Posted February 20, 2020 I'm not sure that the Taper Extrude command is modern enough to do what you want (some tools/commands haven't been updated for a long time). I would suggest making an extrude and using the Deform Tool to taper it. Use the Taper Solid Mode and make sure Symmetric Mode is turned on. Here's an example (first one is an extrude, the second is an extrude tapered with the Deform Tool, the third shows what the Taper Solid Mode does on a simpler shape and the fourth one is both tapered and twisted) - Kevin Taper Tree Trunk.vwx 1 Quote Link to comment
zsaunders Posted February 20, 2020 Author Share Posted February 20, 2020 Thank you so much Kevin. The 2nd option is more what I'm looking for. Could you please backsave your VWX file for VWX 2019? I can only use 2019 for school and I get the below error when I try and open your file. Quote Link to comment
Kevin McAllister Posted February 21, 2020 Share Posted February 21, 2020 Here it is as a VW2019 file. Kevin Taper Tree Trunk v2019.vwx 1 Quote Link to comment
axhake Posted February 21, 2020 Share Posted February 21, 2020 Is this what you are trying to achieve? Quote Link to comment
zsaunders Posted February 21, 2020 Author Share Posted February 21, 2020 Yes, axhake, That is what I am trying to achieve. How did you create that? Quote Link to comment
axhake Posted February 21, 2020 Share Posted February 21, 2020 Extruding from an irregular shape such as what you have to a circle are beyond the limitations of Vectorworks and most CAD applications. As a workaround: 1. In plan view; place a circle that will be the top in the desired position 2. Switch to a side or isometric view and elevate the circle to the desired height (vertically) 3. Convert both to NURBS ( Modify > Convert > Convert to NURBS ) Note: If you have selected both and then converted you will need to ungroup. 4. Select your tree (bottom shape) and look in the OIP Check how many "Vertices" your shape has... 65 5. Now select the circle and... ( Modify > 3D Power Pack > Rebuild NURBS ) In the "Number of Points" enter the number of vertices that the lower shape has (65 from step 4 above) select OK. 6. Select one of the shapes and in the OIP tick "Show Direction" Check that both shapes are in the same direction; if they are different this wont work or you may end up with some twisted shape. If they are in different directions select one of them and in the OIP select "Reverse Direction" 7. Switch to plan view as easier to select Select the "Loft Surface Tool" from the 3D Modelling toolset. You want to select the 1st option "No Rails Mode" Now select the lower shape first then the circle (as we converted this to NURBS with 65 vertices it is no longer a true circle which is what makes this work) Try and pick the two shapes in line as shown in the image below (from a vertices to vertices ) Select the "Green tick" to accept. The "Loft Creation" panel is displayed, select "Create Solid" then OK Switch to 3D view and you should have as close a possible to what you are trying to achieve. Hope this helps Alan 4 Quote Link to comment
zsaunders Posted February 21, 2020 Author Share Posted February 21, 2020 @axhake Wow. Thank you so much, I will give this a try! Quote Link to comment
axhake Posted February 21, 2020 Share Posted February 21, 2020 You don't have to do (step 4 & 5) I just like to keep things balanced when modelling and translating to different CAD systems it sometimes helps. It will work once you have converted to NURBS. Let us know how you get on. Alan 2 Quote Link to comment
BobWeaver Posted April 9, 2020 Share Posted April 9, 2020 (edited) Although this discussion is more than a month old, I recently encountered the same error message as in the first post, when I attempted to do a tapered extrude: "Tapered Extrude creation failed due to invalid parameter(s) for at least one profile object." Reading through this discussion, I decided that lofting would not be suitable for my situation, because the start and end shapes needed to be the same—just different sizes. The shapes I was extruding were characters of text that had been converted to polylines using the conversion command from the Text menu. About 90% of the characters would extrude properly, and the rest would fail with the above error message. So, I decided to do a bit of detective work. Double clicking on the problem characters, and looking at the vertices, I saw that there were places where vertices were clustered very close together. In some cases the vertices appeared to be superimposed, and occasionally one or two that were in reverse order. I was able to remove some of these vertices and move a few others without having any significant effect on the shape. After I finished this editing, the tapered extrude was successful. So, this is one possible solution to the problem. FYI: This is a type-wheel design for a printer. See attached image. The taper is 10° on the characters. Edited April 18, 2020 by BobWeaver Added image 3 Quote Link to comment
