axhake Posted February 17, 2020 Share Posted February 17, 2020 I have received a point cloud file in .pts format and have imported this into Vectorworks 2020 Sp2.1. I have played around with different combinations of settings but the imported point cloud is always coming in centered about 0,0. As a check I have imported the same point cloud into Microstation and this aligns in the correct coordinated space. Is there a trick I am missing or is there a problem with the import of point cloud data in to Vectorworks 2020 I've created an extract of some of the points for testing (first 3000 point) as the original file is large and takes considerable time to import. Attached below for reference (had to zip the file as .pts file extension not acceptable to upload) Extract - to world Coords.zipExtract - to world Coords.zip Quote Link to comment
0 Vectorworks, Inc Employee Tamsin Slatter Posted February 17, 2020 Vectorworks, Inc Employee Share Posted February 17, 2020 This is an issue I have reported to our engineering team - VB-167146. Quote Link to comment
0 axhake Posted February 17, 2020 Author Share Posted February 17, 2020 Thank you 1 Quote Link to comment
0 Vectorworks, Inc Employee Tamsin Slatter Posted February 17, 2020 Vectorworks, Inc Employee Share Posted February 17, 2020 If you still have access to 2019, it does import in the correct place there. From that point, you can centre the geometry on the internal origin and you'll be good to go. Quote Link to comment
axhake
3 answers to this question
