Alex Neumann
Adjust flipped text in a viewport
Hi Friends,
I have a conundrum with "Adjust flipped text".
I'm working in a viewport in which I want to rotate text upside down (I know, sounds weird...but I have my reasons). If I unselect "Adjust Flipped Text" in the viewport's advanced properties it still does not allow me to have upside down annotations...HOWEVER if I go to document settings and unselect "Adjust Flipped Text" it lets me do it in the viewport.
I generally like to drive Vectorworks with Adjust Flipped Text selected in the overall document, but sometimes want to make non-standard choices with how I annotate viewports, which I would imagine is why this option exists in the OIP for a viewport...but appears to do nothing.
I've been working in Vectorworks 2020, but exported the file back to 2019 and found that the behavior is the same.
I would appreciate any insights!
Alex
Update after bashing my head against the wall a little further:
If I go into document settings and uncheck "Adjust Flipped Text" and then go back to the viewport and rotate the annotations to where I want, and then go back and check "Adjust Flipped Text" the text stays in the upside down orientation.
Can anyone from Vectorworks weigh in on this? This seems like a bug.
Rotate the text by 179.98° instead of 180.  Then 0.02° difference is enough to convince the Adjust Flipped Text algorithm to not correct the text orientation but small enough as to not be noticeable when viewed in the drawing.
