MultipleWays Posted February 11, 2020 Share Posted February 11, 2020 Anyone ever see this issue? Know a cause/solution? The file is fine in AutoCAD, but importing into Vectorworks messes with the arcs. All of the attributes are correct, except they've been given different start/end points. 1 Quote Link to comment
Dishav Vasudev Posted February 12, 2020 Share Posted February 12, 2020 Hey @MultipleWays , I have had this issue in the past when exporting DWG. Drag'n'Drop the DWG into Vectorworks till a pop-up dialogue box appears 'DWG Import Options'. There is an 'Advanced' button (bottom left), click on that for options, I would suggest to play with the 'Location' category. I assume the 'Align with Internal Origin' would be best suited for you. Hope this helps! Quote Link to comment
MultipleWays Posted February 12, 2020 Author Share Posted February 12, 2020 @Dishav Vasudev I tried playing with the location settings with the same result. Under the 'conversion' category, there is an option to 'Convert all objects to 2D'. That worked! Quote Link to comment
