Andy Broomell Posted February 11, 2020 Share Posted February 11, 2020 How do I get the vertical frames of a Curtain Wall object to display the 2D attributes set up in the Frame Settings? They seem to only display as white and I'm not sure where this is coming from... Am I doing something wrong or is this a bug? Quote Link to comment
DBruhnke Posted February 11, 2020 Share Posted February 11, 2020 @Andy Broomell If you change from a Hatch to a solid color is it showing properly? Is your hatch small enough to be seen on a 2" x 6" rectangle? Quote Link to comment
Andy Broomell Posted February 11, 2020 Author Share Posted February 11, 2020 14 minutes ago, DBruhnke said: @Andy Broomell If you change from a Hatch to a solid color is it showing properly? Is your hatch small enough to be seen on a 2" x 6" rectangle? No, even when set to a solid color fill they display as white. Quote Link to comment
Andy Broomell Posted February 11, 2020 Author Share Posted February 11, 2020 Also... if I set the "Cut Plane" height in the OIP at a height taller than the wall, then the Frames do display the hatch, but of course then I lose my my glazing and any door openings... So the issue seems to be with objects that are "cut through" displaying the white fill instead of their assigned fill. Quote Link to comment
DBruhnke Posted February 12, 2020 Share Posted February 12, 2020 14 hours ago, Andy Broomell said: So the issue seems to be with objects that are "cut through" displaying the white fill instead of their assigned fill. That's odd behavior. Not seeing that on this end. Cut Plan above still shows them filled. Quote Link to comment
Andy Broomell Posted February 12, 2020 Author Share Posted February 12, 2020 I copied the object into a blank file and am attaching it here. CurtainWall.vwx Quote Link to comment
Guest Wes Gardner Posted February 12, 2020 Share Posted February 12, 2020 @Andy Broomell, I played with it for a time last night and got what you're getting...just so you don't beat your head on the wall too long...I haven't time to do a thorough look-see but my guess is something's amiss... Wes Quote Link to comment
Judy Cosgrove Posted February 12, 2020 Share Posted February 12, 2020 Curtain Wall tool drives me crazy. In the past whenever I would try to edit one horizontal up or down, the rest of the horizontals revert to some default, and I would have to re-do everything. More recently I stopped using it and create them with extrudes. 2 Quote Link to comment
DBruhnke Posted February 12, 2020 Share Posted February 12, 2020 3 hours ago, Andy Broomell said: I copied the object into a blank file and am attaching it here. @Andy Broomell Having the same results as you Andy. Have a pretty good feeling that it will be fixed in the next Service Pack. 😉 #JusSayin Quote Link to comment
