changes made in a drawing in design layer (1:1) won't show up when I view drawing in sheet layer (1:50).
Jan.m
3 answers to this question
To expand on Michales comment.  The default is for new layers and classes to be invisible in viewports that have already been created. So if the objects you have drawn are in a layer or class that did not exists or was set to invisible when you created the viewport they won't show.
You can either click the Layers or Classes button in the OIP with the viewport selected to edit a single viewport, or you can use the Visibilities mode (button in upper right) of the Organization manager to see and control what layers and classes are visible in each viewport.
