Martijn Theunissen Posted February 7, 2020 Share Posted February 7, 2020 Hello everyone I am currently experiencing a problem with my IFC/marionette objects. I have linked records to my marionette objects, for example IFCWall, IFCWindow, IFCSlab.... Now I would like to adjust the materials and components within these records. However, I have already tried this with setRecordField, but without success. Is this possible or does it go too far for marionette? I also add my IFCSlab with the underlying script. Thank you in advance! Quote Link to comment
m.graf Posted February 7, 2020 Share Posted February 7, 2020 @Martijn Theunissen maybe my little tests (from last year) to get the "component_name" from Vectorworks Walls and Slabs helps you... to set your components. Last year i can't get other components value such as "vs.GetComponentWidth". you can find all other "Get or Set components..." here: http://developer.vectorworks.net/index.php/VS:Function_Reference if you get or set the other values please post it here. test.vwx Quote Link to comment
m.graf Posted February 7, 2020 Share Posted February 7, 2020 (edited) sorry, first i misunderstood your question: To set data you can try this IFC nodes. It is possible in "pSet Database" , other values in IFC_Slab such as Material / Component i didn't found a solution. Edited February 7, 2020 by m.graf Quote Link to comment
m.graf Posted February 7, 2020 Share Posted February 7, 2020 (edited) I have the solution... without the own Database and IFC PSet set_IFC.vwx Edited February 7, 2020 by m.graf 1 Quote Link to comment
Martijn Theunissen Posted February 10, 2020 Author Share Posted February 10, 2020 Thank you very much! This is indeed the solution, even the vectorworks helpline couldn't find it. Quote Link to comment
