Carolina Hdz
Create Property Line Report
Hi! I have a problem creating reports after i made my Property Line.
In the videos i've watched it says the report creates automatically when you make your Property Line but in my case, i can't find it or create it with Tools: Reports: Create Reports: Preformatted Report: Property Line-Segments
I don't know if i'm doing it the right way or if i missed a step or something. I attach a photo of what i get when i do the report.
Thanks!
It looks like you have found a realtively simple bug in VW2020 (and maybe before).
The Segment Record format has a Angle misspelled in the field names as Angel.
Double Click to edit the  worksheet. If you see Row 3 you are all set. If you only see 3.1, 3.2, etc. you need to go to the worksheet View menu and select Database Headers.
Click in cells B3 and C3 and edit the formulas to say
=('Segment Record'.'Angel Bearing')
=('Segment Record'.'Angel Azimuth')
And you will be all set.  Unless VW decides to fix the bug about the misspelling that I am about to submit 😉
In which case you will have to go back and undo the edits or create a new schedule.
