Help Required for Simple Parametric Polygon
Hi all,
I am trying to create a very simple 2-D Door Jamb (see PDF attached for visual cue) which I want to use for a Door Marionette that I created. And I have tried for hours with different nodes to get the result I need but it is not working.
So I ask, if my starting approach is the correct / efficient method or is there a better one that I may have not considered?
2-D Door Jamb - Values and Parametrics
The 'bold black' shape is created by individual lines with fixed points which I want to be temporary as highlighted in red. Those are values I want the user to input.
I.E. if the wall thickness (a) is 200mm, then Door Thickness line will change to accomodate the change in wall thickness(b). Also, I want there to be a fixed length of 45mm highlighted in blue, which will then give the door thickness (b) distance. Makes sense?
To make it more complicated, I want the option to add a constraint of the wall thickness (a) value, so it does not go lower than 60mm.
I hope I am making sense with the diagram below. I have tried various methods to 'Get Distance', 'Find Points in Polygon' but I just dont seem to understand how to draw the polygon shape and also add the constraints.
20200205163000.pdf
Hey @m.graf
Thank you very much for showing me the 2 variants of node networks! It's really helpful to understand a different process and your's actually works! I will try and use the methods you shown and create what I need to!
One Question on your first variant: The node 'Enhanced Rectangle' seems to be one that you created? If so, what is special about that node as I have no knowledge of scripting but I can see you've added a node of your own?
Many Thanks,
Dishav
the node "enhanced rectangle" was created by Member "DomC", he create most of the best Nodes and Tools here. 🙂
the Enhanced Rectangle Node is much better then the normal Rectangle Node in VW
@Admin - it's sad, that these node (and other new nodes) are not implemented in VW's - Node library!
 greatings M.Graf
