Jumper Cable
AlexSawaya
Greetings.
It is happening to me in the MAC version, which when using the "Jumper Cables" tool is displayed as shown in the capture (Red Color) In black, use the "Power Cable" tool.
My question if anyone knows, why in the jumper cables (red) all those perpendicular marks on the path come out, thickening the line.
In Win 10, it doesn't happen to me.
Any ideas if it's a setting or something I'm doing wrong?
From already thank you very much.
1252545994_Capturadepantalla2020-01-28alas11_20_07a.m..thumb.png.2b2e23daa3c85742813a8b4740ec154b.png
2025721430_Capturadepantalla2020-01-28alas11_20_19a.m..thumb.png.6bbf5aa90741b1a04040a5148dcd292b.png
1479825094_Capturadepantalla2020-01-28alas11_20_30a.m..thumb.png.c3e761484db2d94a913e027b143b74da.png
10 answers to this question
Complete guess, but it looks like it has been assigned a Line Style. Check in the OIP and see if there is a setting for Line Style that you can change. Just converting to UnStyled is probably not enough as it will leave the settings as they are. You need to change to a simpler line style and then convert to UnStyled if you want it unstyled.
@AlexSawaya I took a look on my machine as well and it looks like what you are seeing are the loci for the Braceworks-Distributed Load class.  This is added to the cables and other items so that the weights can be used to properly calculate all weights in Braceworks.  If you turn off the Braceworks-Distributed Load class the loci will disappear and the line will be thin again.  I am going to file a bug for this today.
