acttheatre Posted January 27, 2020 Share Posted January 27, 2020 Hey friends, our main workstation is experiencing frequent hard crashes (brings the whole system down) while using larger drawings in Vectorworks 2018 and Mojave 10.14.6. The machine is a 5K iMac, 4GB gpu, 32GB RAM. We are about to upgrade to VW 2020 and Catalina but I'm wondering if the crashing will follow the new version. VW has never been terribly stable on the Mac and I'm wondering if it is even worth doing the 2020 upgrade? I can see in the Console logs that the GPU is the thing falling over and crashing, what other testing can we do to narrow down the cause? Quote Link to comment
Vectorworks, Inc Employee jcogdell Posted January 30, 2020 Vectorworks, Inc Employee Share Posted January 30, 2020 What type of GPU is it and how old are the drivers for the GPU? Also how big are the VWX files? Quote Link to comment
acttheatre Posted February 18, 2020 Author Share Posted February 18, 2020 The files range from 20MB to 160MB. We only use the Apple-provided drivers. So whatever is installed with Mojave: AMD Radeon R9 M295X: Chipset Model: AMD Radeon R9 M295X Type: GPU Bus: PCIe PCIe Lane Width: x16 VRAM (Total): 4 GB Vendor: AMD (0x1002) Device ID: 0x6938 Revision ID: 0x0000 ROM Revision: 113-C773AA-731 VBIOS Version: 113-C773A1-014 EFI Driver Version: 01.00.731 Metal: Supported, feature set macOS GPUFamily2 v1 Displays: Display: Resolution: 5120 x 2880 (5K/UHD+ - Ultra High Definition Plus) UI Looks like: 2560 x 1440 @ 60 Hz Framebuffer Depth: 24-Bit Color (ARGB8888) Main Display: Yes Automatically Adjust Brightness: No Quote Link to comment
zoomer Posted February 18, 2020 Share Posted February 18, 2020 (edited) I think your iMac is well within Specs. So if there is no Problem to find on the software side, not very likely, but there could be something hardware related too. I think your iMac is up to 6 years old (?) I could imagine that meanwhile there came some dust in the fan(s) and the thermal paste may be dried. In that case the cooling would be limited and that could lead to GPU problems when it gets too hot. But you should be able to notice that when the fan runs noticeably faster than you were used to when it was new, even with low loads. (Like my mother's 2006 white plastic iMac ?) And it is worth to check temps under load with an App that can read temperatures, like iStat Pro. If that would be the case it may be worth to order the suitable iFixit Kit to open and clean up the case. Maybe even upgrade some RAM and SSD. Edited February 18, 2020 by zoomer Quote Link to comment
