How to remove this angled area from a solid?
u3rick
4 answers to this question
I'd draw it by lofting and then use the Push/Pull tool to subtract the 45º and 60º chamfers. Here's an example (there's something weird about the proportions vs. dimensions on the original drawing) with each step.
- I drew the bottom profile curve, copied it, moved it up and adjusted its length.
- I converted both curves to NURBS and lofted them using the first mode of the loft tool and the Create Solid checkbox checked.
- I drew guides on the side for the two chamfers.
- I used the third mode of the Push/Pull tool to remove the 45º chamfer and then the 60º chamfer.
Kevin
1264985106_ScreenShot2020-01-27at11_31_43AM.thumb.png.052e8a9269d408bffdedc12c667d153c.png
V Shape v2019.vwx
