Bean Posted January 26, 2020 Share Posted January 26, 2020 (edited) Hi! been using the data chain tool and i want to add 2' automatically to the length for focus room. is there a way to do this? a setting i missed? thanks! -Bean Edited January 26, 2020 by Bean Quote Link to comment
Vectorworks, Inc Employee jcogdell Posted January 27, 2020 Vectorworks, Inc Employee Share Posted January 27, 2020 There are 2 ways to accomplish this, When the make data cable chain command is run for the first time and you have finished selecting the fixtures, the preferences dialogue will open. In the calculate parts section enter the desired length in the 'part 1vert dist' field, note: make sure you enter the desired length including both ends of the cable, so in your example because you want 2' at each end you need to enter 4'. The second method is for all subsequent uses of the make data chain command after running the command, the data cables will automatically remain selected. Use the OIP to enter the desired extra length, same workflow as above. note: you will only have to change the 'part 1 vert dist' field if you want a different value from the previous use, as the command remembers the last value entered. Quote Link to comment
Bean Posted February 4, 2020 Author Share Posted February 4, 2020 awesome thank you! success! Quote Link to comment
