Tanner Shelton Posted January 24, 2020 Share Posted January 24, 2020 Does anyone know what the differences, or if there are any differences, for rendering on a project with a 1:200 scale instead of a 1:1 scale? I'm mostly curious if changing scale like this would modify values or attributes or mess with anything? I bring this up because I am adding bloom to my project and the bloom seems very large. I'm working on a 1:200 scale as that is what is requested by my boss. Quote Link to comment
Vectorworks, Inc Employee Luis M Ruiz Posted January 27, 2020 Vectorworks, Inc Employee Share Posted January 27, 2020 May I have a bit more information about your renderings workflow? what steps do you take? what style of rendering do you use? Quote Link to comment
Tanner Shelton Posted January 27, 2020 Author Share Posted January 27, 2020 I use Realistic Interior Final or Fast most of the time. I generally model everything in the scene, usually an interior venue and then all of the event items, then I texture and light then render. Quote Link to comment
Vectorworks, Inc Employee Luis M Ruiz Posted January 27, 2020 Vectorworks, Inc Employee Share Posted January 27, 2020 Good start, tank you. Ok, here is a recipe I recommend: 1- While in design layer, set your desired view and save the view so you can always come back to it at some point. Then create a viewport, place it on a sheet and set resolution to 300 dpi. Size? how about starting with a letter size, landscape. 2- Rendering: Use Custom Renderworks, that way you control over the settings. Fast rendeworks is all low (good for preview) High quality is all set to high (may be too slow) 3 - Lights first, then light bounces, then background, then materials and finally adjusting the resolution of your settings 4 - If things go as planned then export sheet as png, jpg, photoshop or tiff, depending on who need the rendering. 5 - Keep in mind that Image effects can add a punch to your renderings. Quote Link to comment
Tanner Shelton Posted January 27, 2020 Author Share Posted January 27, 2020 I don't think that really answers the initial question I asked about differences in scale? Quote Link to comment
Vectorworks, Inc Employee Luis M Ruiz Posted January 27, 2020 Vectorworks, Inc Employee Share Posted January 27, 2020 triangles is what matters. If you have a forest with 3d leaves, that would take forever. Then again, renderings are views, so scale is not an issue. Do not create renderings from the design layer, use viewports. Quote Link to comment
