LiamSayer
Rotating Label Legend Fields
Hello. Long story however I need to have some fields in a label legend upside down. I've tried making sure right reading is off and physically giving the field a rotation of 180º. Any ideas? Running VW2020
Make sure that Flipped text is turned off in your document preferences or if you are using a viewport, then turned off in Advanced properties of the Viewports Object Info Palette.
You must change the Document Preference BEFORE creating the Flipped Text.
If you have the Document Preference Set to Adjust Flipped Text, the text it creates is "fixed" for the life of the text.
Once you turn the preference OFF, new text will respect the flipped orientation, left, right, backward, upside down and backward...
If you then VP the flipped around text, and set the Advanced properties to Adjust Flipped Text, you will see the change.
