2D Geometry not showing up on Hybrid symbol
CourtneyM
2 answers to this question
Check the symbol in the Resource Manager.  It probably has a 3 next to it, indicating that it is a 3D symbol.  If so, then the 2D elements are being treated as 3D.
Edit the 3D part of the symbol.  You will see the 2D objects laying on the "floor".  Select them.  In the OIP change the plane from whatever it is to "Screen".  When you exit the symbol you will get a warning that you are changing it from a 3D to a hybrid.  Say OK.
In the Resource Manager the 3 next to the symbol will be gone, indicating that it is a hybrid symbol.
