r.cipriani
Intersection of two NURBS curves
I need to find the intersection of a set of NURBS curves, basically obtained from the "Contour" tool from a mesh surface.
By hand, I can select the "Analyze" tool and then click on the two curves and get a 3D Locus on the intersection.
How can I obtain the same result using a script?
I tried to select the two nurbs and then calling the tool, but obviously "Analyze" wait for the clicks...
There is a way to automate this?
Thank you
roberto
Because NURBS curves can intersect at from zero to an infinite number of points, I don’t think VectorScript is equipped to automate this.
Thank you.
I believe there is some algorithm that do this calculus, because the “Analyse” tool work.
