murky Posted September 4, 2005 Share Posted September 4, 2005 Does anyone have any suggestions as to why the snap function does not work when clicking to objects in other layers even when the Show/Snap/Modify is selected in Classes and Layers? It works when I am Active in some layers but not in others. Thanks! Quote Link to comment
mike m oz Posted September 4, 2005 Share Posted September 4, 2005 Snap functions between layers will not work if your layers are: - Not in the same view orientation (eg. Top/Plan) - Different scales. Check to make sure that you do not have either of these two conditions present. Quote Link to comment
Cerveza Little Posted September 16, 2005 Share Posted September 16, 2005 I'm having the same problem and just posted a thread before reading yours. I am running all layers at the same scale and all the views are the same. Quote Link to comment
mike m oz Posted September 16, 2005 Share Posted September 16, 2005 Other possibilities are: - That you are using different Classes and have Class Options set to Show Others or less. - You have inadvertantly turned the Snaps off on the Constraints Pallete Quote Link to comment
