Richard1 0 Posted January 16, 2020 This function does not return nil on failure (VW2019 SP5.3), instead it seems to be returning the original object. Worse, I have not been able to find any documentation as to which object types are supported by the function. So far I have found that passing it a kLine2D returns the original object, thus the following snippet destroys the original drawing: MCObjectHandle tempPoly = gSDK->ConvertToPolygonN(h, (Boolean) true, 512); DoSomethingWithAPolygon"d(tempPoly); if (tempPoly) { gSDK->DeleteObjectNoNotify(tempPoly); } Fortunately this causes our plugin to crash, so our users have not lost data (yet) Quote Share this post Link to post
Stefan Bender 7 Posted January 16, 2020 Maybe you can check if h == tempPoly to avoid these crashes. Quote Share this post Link to post
Stefan Bender 7 Posted January 16, 2020 IIrc we are using the old function (without N) in our code. I think it works fine for polylines, rectangles and arcs. I don't know if we are passing other object types. I'm not sure if it is possible to create polygons with less than 3 vertices. Quote Share this post Link to post
