Delimiters? Different by Language/County?
I think my archive might have gotten too big, because I am sure this has been discussed before, but I can't find it.
The basic question is:  How can you right a script that will run anywhere if it depends on how things are delimited.
In the US we use a period (.) as the decimal point. In many other countries it is a comma (,).
In the US we use a comma (,) as the separator in a CSV file, in Europe it is a semicolon (;)
I am considering a script that will read the formula out of a worksheet cell [=record.field format] and then I want to be able to extract the record name and field name. I can do that relatively easily using Copy, Pos, and SubString, but only if I am certain what the delimiter character between the two parts of the field are. Is it always a period? Or is it a comma in some languages/countries?
Since I think this is actually based on the operating system settings, it is not even a easy as having different versions for different countries as someone could set their OS up differently.
How do I determine what delimiters are used or how do I write a script that is delimiter independent?
I think I was bitten by this in the last couple of weeks where a script I posted had to have the commas changed to semicolons but I can't find that thread either.  Grrrrr.
OK Gurus what am I missing to make this work?
Was the script you posted in my thread “insert values referred to Working Plane in a Worksheet”
I am under the impression that if you send a .vwx file containing the script the separators are always correct.
