Moley Campbell Posted January 15, 2020 Share Posted January 15, 2020 Hi, When I create a sweep it looks fine in open GL, fast renderworks, artistic render works etc but in hidden line, wire frame or sketch it reverts to the polygon/shape it was made from. So I can't see the drawing properly as a view point and it's really difficult to work with in the design layer. It didn't use to do this so I wonder if I've changed a setting by mistake...which one though I haven't a clue! Please help, Moley PS I'm using VW2019 Quote Link to comment
michaelk Posted January 16, 2020 Share Posted January 16, 2020 In the hidden line options take a look at the smoothing angle. 20 to 30 is usually the sweet spot. And with sweeps it's I find it makes VW happier if you turn the sweep segment angle as high as you can stand it. I usually default to 20º. Very low segment angles can bog the drawing down. If that doesn't work for you post an example of the sweep. It's possible to get a self intersecting piece of the sweep that can produce interesting results. Quote Link to comment
Moley Campbell Posted January 19, 2020 Author Share Posted January 19, 2020 Thanks Michael, I've attached a few screen shots to show what the problem is - changing the smoothing angle don't seem to help unfortunately. Moley Quote Link to comment
michaelk Posted January 19, 2020 Share Posted January 19, 2020 I'm not able to recreate it. Can you send me a file with just the sweep? Quote Link to comment
Moley Campbell Posted April 24, 2020 Author Share Posted April 24, 2020 Hi Michael - so sorry I didn't get back to you! Thank for getting back to me though. I got distracted, then totally forgot - sorry. I I happened to be going on a course to learn Twinmotion - and the guy running the course showed me what I was doing wrong, (to do with sheet plane and layer plane). The reason I noticed that I'd forgot is because I went back onto the forum just now to see if there is a way to detail the Glasing bars in the windows... I'm working on a few buildings that are meant to be from the C18th and they look weird with the boxey glasing bars and frames and keep having to build the windows from scratch. Yours apologetically, Moley Quote Link to comment
